RE: Engine mounting problems 8ight-t v1.0
I made some spacers to add to the engine mounts on my X1 when I used the pull start engines. Just get higher mounts or space it a bit. I used 4mm aluminium as a spacer, cut to size and drilled 2 holes per side.</p>
</p>
