Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 Engine mounting problems 8ight-t v1.0 >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 06-01-2009 | 05:26 AM
mentat's Avatar
Default Engine mounting problems 8ight-t v1.0
I recently bought the mach 427 engine which came with a pull start. with the pull start attached it will not allow the engine to connect properly to the engine mount on the 8ight-t. I am guessing that i have to either purchase a new plate or something else. I do not want to use bump start. is there some kind of way to use pull or roto start? grr its one thing after the other i haved to buy. Got a new engine cant use it because the mounting of the pull start. any help would be appreciated. Thanks!
Old 06-01-2009 | 06:32 AM
RevoG's Avatar
Default RE: Engine mounting problems 8ight-t v1.0
I made some spacers to add to the engine mounts on my X1 when I used the pull start engines. Just get higher mounts or space it a bit. I used 4mm aluminium as a spacer, cut to size and drilled 2 holes per side.</p>
</p>
Old 06-01-2009 | 01:30 PM
Why dont you want to use a bump box? They do make conversion kits to make your mach into a bump motor..and if you use the Losi box its easy..I always hated pull starts for several reasons..
Old 06-01-2009 | 02:29 PM
I assume you have the 8T kit, so I guess you need the RTR mount...  It is, after all, the 8T RTR engine..  Only difference is the RTR came with a Spin-start backplate, but size-wise it's the same as pullstart(I believe..)
Old 06-01-2009 | 04:46 PM
You are corect on the size..I still say ditch the pull start and go with the bump box..one way bearings are nothing but trouble..
Old 06-01-2009 | 07:39 PM
This is what you'll need if you'd like to keep the pullstart or rotostart:
http://www.amainhobbies.com/product_...ducts_id/20116
It says 8B, but I'malmost positivethe 8T RTR uses the same mounts.
-Howard</p>
