RE: FUNJET
Lucky, YES the MEGA 16/15 TWO TURN motor is insane! I have tried so many different props, but the 6X3 APC seems the best for speed and pure vertical!....
(If you,re not familiar with the Nelson Q-40 engines, you ought to be next to one when it is fired up! it has only a BIG venturi carburetor, with no throtle! It does not sound like a conventional engine, with the usual "WAGGGHH" sound, it has a HOWLING SOUND! The RPM's are in the 35K range!! The price is around $435.00, but you can not find a better engine in the world! If you put one of those on your Diamond dust, you better have a clean pair of underwear with you. LOL!)
I,m curious, is ANYONE out there using a Mega 16/15 2 motor on their FJ? If so, I would like to hear from you....
Thanks, Paul
