RCU Forums - View Single Post - new to nitro, need help with setup
Old 06-02-2009 | 05:13 PM
teejayv
Default new to nitro, need help with setup
Hello all, just needed a little help on a few small things to start with since Ijust purchsed myself an Avalanche XP, and as Iwas looking through the manual, it says to "adjust the clutch bell" and from what I gathered, it was improperly worded in the manual, but Iget the gist of what I'm supposed to do. My questions are these though.... first off, do you need to adjust the clutch bell or should it have come adjusted from the factory?Irolled it on the ground, did the "1/2inch by 6inch" paper trick to check the space, and it all seemed good, am Ipossibly missing something?And secondly, when I loosen those screws, am Iactually supposed to remove them to put the loc-tite on the threads and then do the adjustment?Any help would be greatly appreciated, thanks!
