RCU Forums - View Single Post - adjusting needle
Old 06-03-2009 | 09:56 AM
HighPlains
Default RE: adjusting needle
Remote needle valves like on some OS engines, or angled needle valves that move it further back than the standard setup.  I've had some airplanes with the needle valve inside the cowl, so I had to kill the engine to change the setting.  Since you may only change the needle one or twice on any particular day, this worked OK once the initial setting was found.
