ORIGINAL: daz spit
thanks for your input mate but spit has alreadybeen built and flown. heavy anyway 281/2 LBS may not be able to put diff push rods in elevater i was not happy with elev to mutch slop .by takeing out the push rod and giant servo that works it and putting two servos in tail and makingelevater and rudder lighter it will prob end up being about the same weight just want to now what torque perservos would be good.it flyes very well at that weight thanks for your help
Daz spit,
I am with the other guys in saying "keep the tail light' If you add a servo or two way down the back or close to, then you will need many times weight worth up front. But you know that. Any way I am using an eight and a half KG torque servo for my elevator. If you are going to use two you could get away with fours or five kg of torque.
Cheers.
Brad
