RE: Starter battery setup
Nope, those small connectors will NOT do it as you are pulling too much current.
There is a ready made connector set from Tower which does the trick;
[link=http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=LXMTZ3+&search=Go]Click me for the connector.[/link]
You'll then just need to wire in the corresponding connector on the starter.
That's it. Two solder points and heat shrink and your done.
