RCU Forums - View Single Post - Starter battery setup
Old 06-04-2009 | 10:28 PM
  #42
cappaj1's Avatar
cappaj1
Default RE: Starter battery setup
ORIGINAL: opjose
Nope, those small connectors will NOT do it as you are pulling too much current.
There is a ready made connector set from Tower which does the trick;
[link=http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=LXMTZ3+&search=Go]Click me for the connector.[/link]
You'll then just need to wire in the corresponding connector on the starter.
That's it. Two solder points and heat shrink and your done.
Yep, thanks, but I already ordered that as you had recommended earlierI was asking about charge leads for Tamiya to banana.
