RE: spinner
Carl Goldberg spinners are snap together, that may be what you have. There are several little slots that you slide a small screwdriver into and twist gently and the cone will pop loose from the base. The things on the bottom you are seeing are what holds it together, don't mess with them. Look for the little slots on the outside circumference of the base.
