RE: Futuba 10C programming help
Check your prog mix screen. If the switch is working you will see the mix setting turn on and off. Sounds like you have your rate set at 0%. Set to either + or - 100%. Remember, you can only use half of the slider in order to use the offset on the trainer switch. Set your slider in the middle and chooseto useone way or the other in your endpoint menu. I think this is where you are going wrong.
