RE: dazzler arf
well bad news. i think the dazzler is junk. i am going to take all my stuff out of it and pull the coating off it. it broke the engine off the front and pulled the wing off the wing pocket. plus some damage to front of wing.there is some tail damage also but not bad.
what happened as far as i can tell i came out of a dive and pulled up and after that it would only fly inverted with full down. so i pulled the throttle to idle and ditched it upside down. it was not busted into pieces but it is not great also.we did find the elevator had a half broken off. i am thinking it failed when i pulled out of the dive. i may try to fix it. after all it is only glue and time if i can not.
i do not know if i will get a nother one. i liked the way it flyed after i made it stronger.
