RE: Piston ring question
When you compare the 4 stroke engine in a car to a 4 stroke in a model airplane you must consider that the oil is in the fuel and must be blown through the engine in an airplane. In a car engine it is separate and is circualated by a pump. The oil itself also helps add compression to a model airplane engine.
