RE: ENGINE DOWN THRUST ANGLE QUESTION???
The "theories "on down thrust are pretty darn subjective
A LOT depends on the speeds yo like to fly.
Why the larger engine?
A whim?
essentially th model is of a size and the wing setup makes for a lot of climb under power
The huge down thrust was likely done to increase speed yet hopefully provide some force to keep the nose down
You can screw around with the speed n downthrust and the wing saddle position till the cows come home
BUT the stock setup makes for a gentle very ,very easy model to fly.
My old Seniorita can quickly be trimmed for complete hands off flying - it will do huge circles with a gentle undulating flight path
meaning the model will slightly climb till speed drops back then dive slightly picking up speed and the nose will gradually come up -repeat etc.. lovely free flight flying
If you are after an aerobatic setup , the basic model arrangement is wrong -so once you dig into more power for more speed you wil end up having to change angles of wing and thrust -or just accept it is what it is.
