RCU Forums - View Single Post - Ugly Stick Build
Old 06-09-2009 | 09:16 PM
  #136
stikman63
Default RE: Ugly Stick Build
Uncle willies mod. of the jenson plans were the best(.Lazer-works.comhas short kit basedfrom these plans.I sent them 2yrs. ago. Go to L.W. and you will see that plane and a94" Tele master I built.)He removed the dihedral, I built this plane and others like it as a T.D. Nergall use vert. grain sheer all the way leading edge spar,half way trailing edge spar cover well. I did not use the dowel pin and #64 band setup. 2 dowels in center L.E. and nylon 1/4-20 bolts in rear. I've tried taken pics while I build, I get lost in the build and forget all about ths camera. So I will be startin a 106" Hobby Shack ugly stick and into the wonderfull world of gas.
ID:	1215526   Click image for larger version
ID:	1215527   Click image for larger version
ID:	1215528   Click image for larger version
ID:	1215529   Click image for larger version
ID:	1215530   Click image for larger version
ID:	1215531   Click image for larger version
