RCU Forums - View Single Post - matching dual elevator travel
Old 06-13-2009 | 09:38 AM
Walt and Sage's Avatar
Walt and Sage
Default RE: matching dual elevator travel
<span style="color: #ff6600">If you set your elevators as ailevators can you do mixes such as elevator/flap mixes???
Also the other pre programed elevator mixes??? Thanks Walt....</span>
ORIGINAL: ro347
Ah yes....that was the case with the 7Cap(72 mhz)....not so with the newer 7C(2.4ghz). You are able to trim both using the ailevator function/mix.
