ORIGINAL: molo_30
Hi guys, heres the tail pipe out of my Adjets Scorpion. It has a few kink type marks inside as you can see. The largest is about 20mm long.
It has no discolouration. The seam is still welded tight.
Do you think it is safe and if not, best place to get one?
I correctly understand - you (at you deformation) so is rumpled a pipe inside????[:-]
