RCU Forums - View Single Post - BVM Smoothstop II problem
Old 06-13-2009 | 03:54 PM
yf222000
Default RE: BVM Smoothstop II problem
Hi.
I am using the older version of the BVM smooth stop brake valve. Make sure the travels of the plunger returns fully to the end of the valve. Also check to see
if there is any clogs in plunger's relief air hole. If you are using the O ring style brake system, lube those O rings up so that it could contracts back into the brake hub's
grooves once the air is bled out from the valve. Good luck.
