RE: Tail pipe help
Hi ; In my opinion you have had an overtemp situation ; IE: hot start or tailcone fire.
Since you said the integrity of the tailcone is still there you could probably fly it with not problem but will most likely have a reduced thrust rating.
Iwould also suggest monitoring it after every flight or run while ordering a new tailcone.
Good luck.
