Hi Pete,
I have 2 JR351 servos, wheel brakes and gear valve. No problems with the brake servo but the gear servo does not move full range at times and also will buzz and act as if it's stalled but it will be in mid throw. I put a spare regulator in line temporarily and that solved the problem. Joe Rafalowski put me onto the digital version, I believe they are JR 831. Same size and they will solve the problem.
I'm using a 2300mah A123 with Futaba 6014FS.
Hope to see you at Liberty Bell.
Mike
ORIGINAL: rcpete347
HI all, how many of us are using 123 batteries in our jets, with no regulators( 7.2+ , off the charger and leveling off to 6.5volts for hours), with, say two JR 331 servos and the rest digital. Any negative effect on the non digital servos.
Thanks Rcpete
