RE: Need post surgery entertainment!
If you want a co-axial have a look at the Lama V4. Cheap to keep in the air, good rc uni forum, alloy up grades are every where, alloy swash, head and other parts $10.00-$15.00 USD on you door steep, batteries are cheap, set up for lipos. When you get bored with it set yourself goals like following the walls all the way around a room as close as you can, follow the ceiling line and all other sorts of things. When your on your feet again go buy youself a Hurricane 550 and see if you are as good as you thought you were, Hurricane's are a great heli no matter what some might say. Some like Fords some like GM (I think they might be having a bit of bad luck) It's the same story throughout life, do you start at the top with the best or do you work your way up? Besides, not every body wants the best of a particalar item, some of us would prefer to have good quality and lots of it not the best of one thing only.
