RCU Forums - View Single Post - Engine Problem
Old 06-14-2009 | 10:59 PM
proptop's Avatar
proptop
My Feedback: (8)
Default RE: Engine Problem
ORIGINAL: gaRCfield
Try pulling off the carb and putting it back on tightly before screwing it on. Sometimes air can get around the o-ring seal in an improperly seated carb.
After you remove the carb, clean the neck and draw bar / pinch bolt then use a little Silicone sealer when you put it back together. (just a thin film of it wiped around the carb neck, and the bolt is all you need )
