RCU Forums - View Single Post - Gaui 550 problems!...HELLLLP!
Old 06-15-2009 | 01:46 AM
jerrymac
Default RE: Gaui 550 problems!...HELLLLP!
You will need a draw on the esc to check it. Try plugging the motor wires in only half-way, then hook a volt meter to the connectors while spooling it up and see how much voltage you have to the motor. With fully charged lipos you should have about 25 volts to the motor.
