RE: Tuneing The lrp 30
So on the low end of this motor does it like to be richer on the low side compared to the savage xl? I have richen the high side. It takes off stong and sounds like it dieingabout second gear. Sometimes it will take off stong and cut off. This a little different that what i'm use to as far as tuneing. This more has a lot of power i must say as soon as you hit the gas th power is there. i geared it 17 clutch bell and 49 spur gear i was told that i did not need the 16 52 cause it was more gear than i needed.
