Yeah for the XL...
The header that comes with the Dynamite 053 and 086 doesn't work, not because it can't clear the chassis plate, but because the flat portion of the flange is on the wrong "side" due to it being a truggy/buggy pipe. So the circular portion of the flange doesn't fit due to the .30s pull start cover.
So does one modify the flange on the pipe or the grind down the pull start cover? Iam leaning towards grinding a bit on the plastic of the pull start.
ORIGINAL: BudBud
On an XL? About any header will work, it just has to have enough bow to clear the chassis plate.
