RCU Forums - View Single Post - Checking For Compression
Old 06-22-2003 | 12:53 AM
dbow's Avatar
dbow
Default compression gauge
You can use a compression gauge but you still need to start the engine to get it to the right temp.
Its best to check with the gauge when the engine is new after the break in.
Then you can check it at regular intervals to see how it compares to the initial reading.
Tower sells the gauges.
Dbow
