ORIGINAL: DarZeelon
Of the three rings in most full-size piston engines, the top-most is the compression ring. The one below it is the scraper ring (for scraping the oil off the cylinder walls) and the bottom ring is the oil-control ring.
With model engines not having an independent oil system, the bottom two rings are not needed.
Some model engines do have two compression rings, but they are real vintage stuff.
Agreed.
Bill
