RE: Hog Bipe Build Thread
Finally got a pretty good flight out of my hog, i moved the gear forward1/2" and thought i'd balanced it, but had a bad tendency to fall out of the turns, had to correct with oppisite ailron, so a i rebalanced and now it's much better, still seems a little "mushy" in the turns though, maybe i'm just to used to flyin my SSE, guess the hog isn't quite "flyin on rails" yet. i'm not too sure if i'm still too nose heavy o0r not, i thought about just adding a 1/4 oz to the tail next time and see what happens. Also i did put a washer under the rear top wing bolt, my incedence was vertually dead on with out it, but with it i have about a -1 1/2 degree incedence on the top wing, maybe i should pull that washer out and see how that goes. If anyone has any suggestions it would be greatly appreciated.
