RE: 2.4 GHz Weatronics, PPM or PCM?
Hi
I have the conventional Weatronics RX and find it rock solid regarding RF link. With Futaba radios it can handle 12ch in ppm mode but the downside of this system is that it can only handle 8 proporcional channels in PCM mode and ONLYin 1024.
Iam using it with a lot of internal matches and mixes in the receiver. This receiver works like a top line TX regarding servo programming and can also match servos. If you add intenal gyros and double rx with regulated power supply, you have it all for the price of a top of the line powerbox.
I was planning to change it to ppm mode to have more channels, but I am a bit affraid to fly jets in ppm mode even with the weatronics. Is any one using it in this mode?
It is very sad to me that the 2.4ghz sistem can't work in the fasst mode and as to use a big box on the top of the TX to.
Regards
Nuno
