ORIGINAL: SOLO_48
Can anyone tell me,which way angle the engine,to neutralize the thrust of propeller
If you're standing over the airplane, angle it to the right. But then the engine should be mounted a little to the left to keep the prop hub centered on the air plane center line. This is usually around 1/4" depending on the angleand how long the engine is. Hope that helps.
