Fuel Pump Question
Hi Matt. My saddle tanks on the F-15 were emptying unevenly so I took everything apart to inspect. I noticed that the fuel pump has been just sort of lying on the bottom of the fuselage in front of the forward fuel tank. Ihave 59 flawless flights on the 120SX so I guess I wont change anything. Is this ok? Iwasn't sure if Jetcat recommends hard mounting the pump only or if it's ok that the pump is allowed to "move around". It is wrapped in foam also.
Like Isaid, it's been like this for 59 flights with 0 problems. Just want to clarify.
Spence
