JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Fuel Pump Question
Old 06-18-2009 | 08:04 PM
My Feedback: (60)
Default Fuel Pump Question
Hi Matt. My saddle tanks on the F-15 were emptying unevenly so I took everything apart to inspect. I noticed that the fuel pump has been just sort of lying on the bottom of the fuselage in front of the forward fuel tank. Ihave 59 flawless flights on the 120SX so I guess I wont change anything. Is this ok? Iwasn't sure if Jetcat recommends hard mounting the pump only or if it's ok that the pump is allowed to "move around". It is wrapped in foam also.
Like Isaid, it's been like this for 59 flights with 0 problems. Just want to clarify.
Spence
Old 06-18-2009 | 08:39 PM
FILE IFR 's Avatar
Default RE: Fuel Pump Question
WOW, You never mounted your pump to the airframe???
Old 06-18-2009 | 08:50 PM
My Feedback: (60)
The plane was actually assembled by someone else and the pump is obscured so I didn't even know it was like that.
SM
Old 06-18-2009 | 11:35 PM
ORIGINAL: FILE IFR
typically i don't hard mount mine either, but they don't need to just lay free, I'll wrap them in bubble wrap and poke them in a snug spot for easy removal. if you leave them loose torque can cause a lag in flow as voltages change, it can also twist the lines/wires.
Old 06-22-2009 | 11:03 AM
mr_matt's Avatar
My Feedback: (10)
Hi Spence.
i would worry aount it flupping around so much it broke a wire of kinked a hose. If it is restrained even a bit it should be fine
