RE: choice of edf
<span style="font-size: larger;"><span style="font-family: Comic Sans MS;">KD ... I know you mean wingspan ... that is why I say a 120 cm wing span F16 is not a small plane at all. Hence, you may be in the 90mm to 120mm EDF range. You may get away with 90mm because you want to use foam and it might be light enough.</span></span>
