RCU Forums - View Single Post - Comp ARF Flash update
Old 06-19-2009 | 10:19 AM
  #844
KC36330
Default RE: Comp ARF Flash update
ORIGINAL: JoelP
............... balance at mid-range of published c/g.
i found with mine, 362mm worked out to perfect neutral trim, where all surfaces are lined up flush and best of all, no trim change between slow and high speed flight with it cleaned up. it's so neutral that at modest speed you can slow roll for a mile with just aileron and not loose altitude.
