RE: Comp ARF Flash update
Chaitanya, are you running the full bypass??
it gets hotter than 35C here where I'm at, but we're only 300' ASL and with the Titan SE I've never had any issues, i do not run the lower bypass cover or the inlet ducting, this way the turbine can draw air from the fuselage (mainly the nose wheel hole)
