RE: engine big enough?
Considering where you are on the project, this is what I would do. Find a way to estimate the weight if engine required for best balance. That will give you a clue. I agree with flamin that the 120-4stroke is likely too lo in power. Ags are supposed to be hi powered planes. If you can stand the weight, a G38 or G45 would be a nice match for the airframe. If lower weight is called for there are a bunch of light weight gassers available in the same size class.
Looks like fun.
Bedford
