RE: EVSD-5U-PRO Multi-Function Valve help
Sandor....
You might have something there....
The diagram in the book is 180 out...I set my system with the airlines as per the drawing and I was having a hell of a time getting the brakes to work. They would work with gear up but not gear down. I reversed the physical lines and now the brakes work properly. Perhaps i need to do the same with the door lines??? Can I reverse the valve sequence on the unit itself?
So, just so i am clear, when you have your gear up and doors closed and you boot the system it will automatically put the gear down but it opens the doors first? And if that is true if you boot the system with the gear already down you will still have the doors cycle anyway?
Sorry if my questions are stupid....I have been up way to late trying to get this bird finished!
