RCU Forums - View Single Post - Simjet 1200 ASE startup problem
Old 06-23-2009 | 07:55 PM
yf222000
Default RE: Simjet 1200 ASE startup problem
Hello.
Kerry would be the right person to solve this, but i would like to try while you wait. Please check the glow plug. Make sure its coil is pulled down and outside
of the plug's body about 1 to 2 coils and make sure it si not touching the ground side at all. Check to see if the amount of gas is sufficient to sustain the combustion
temp in the chamber to heat up the kero. Last but not least, check to see if the fuel pump was running during the fuel ramp after ignition of PowerMax. Battery deserve
a good check too. Good luck.
