RE: Getting close to finishing, Two more questions
Hi
One of the things I have seen done is, glue a piece of 1/64 ply in the area around the wing hold down bolts. Another is using a pin, punch holes (not all the way through) around the bolt hole area, then coat with thin CA. Either one should reduce the compression of the balsa.
Vince
