RE: Simjet 1200 ASE startup problem
Kerry,
Thanks for the info. It is a 1200 14lb turbine that i got from Mike spendle. I will have to take a look at the starter to see what needs to be done there. I'll try the Oil and then look at the O-ring. The only reason I questioned the Idle is that it pushes my Bobcat forward at a pretty good pase just on Idle without giving and throttle.
