Perry oscillating pump?
My four stroke engines lean out too much between full tank and empty. If I set the needle slightly rich of peak when the tank is empty and then fill the tank up, rpms are nowhere near max. The fuel tank in both planes is too low (top of tank slightly below carb).
Is it possible to fix this problem with a pump? Does the Perry oscillating pump regulate fuel flow, or does it just boost pressure? Cline regulator?
