Perry oscillating pump?
No matter where you mount the engine, it will lean out as the fuel level in the tank drops while flying. Because of this you must set the needle richer than you may like at the beginning of the flight to be sure it doesn't lean out too much towards the end of the tank. A pump will eliminate this and the engine will run the same at the end of the tank as it does at the beginning.
John
