RCU Forums - View Single Post - EVSD-5U-PRO Multi-Function Valve help
Old 06-26-2009 | 01:15 AM
digitech
My Feedback: (10)
Default RE: EVSD-5U-PRO Multi-Function Valve help
ORIGINAL: SinCityJets
Dirk,
Just to clarify what is happening, here is the simple version:
We store the planes with the gear retracted.
When we turn the plane's receiver ON, the gear wants to extend, which is normal.
In Mode 1, there is no problem, the valve opens the gear AND Doors.
In Mode 2, there is a problem. The gear wants to open, however the DOORS are held shut. This is a problem because the gear could break the doors, while trying to extend.
Chad
Dirk means have you checked this?
4. Please notice the valve surface light change V1~V4. (in mode 2)
*(mode 2) The normal change light is as follows :
On power → V2-(Gear in) & V4-(Door close).
Press " MANU" button → V4 Jump V3-(Door open) → V2 Jump V1-(Gear out) → V3 Jump V4-(Door close)
