Jamara super chipmunk 52
Has anyone tried this one? I just ordered it and have a few questions. The specs page says it's 5.75 lbs, is this the weight without the motor and radio? or reccomended flying weight.
and at that weight a .40 seems a little light on power for aerobatics. (it is supposed to be a .40 size) below you will find the dist's spec data.
Also I can not find any reviews on it so if you've flown one please chime in as well. I need to know how much motor needed to get unlimited vertical pull.
Thanks, Miloh.
Features a beautiful colored gel-coated fiberglass fuselage. Wings are pre-built multi ply balsa and pre-covered. Comes with a full decal sheet! You can be in the air in only a few hours with this awesome ARF plane. Specs: Wing Span: 57.5", Wing Area: 387.5 sq. in.", Length: 45", Weight: 5.75 lbs., Engine Size: .40 2 Cycle, .52 4 Cycle Required Radio: 4 Channel
