RE: Official F27 Stryker Part 8: Beginners to Custom Darkness
I used nichrome wire from a model rocket engine wire to melt the foam and then set the CF tube in the cutout and then checked that the wing was not bent and then used epoxy with micro balls to set it in place. the next time I do this I will but the bass wood on the trailing edge first to help keep the wing from bending
