RCU Forums - View Single Post - EVSD-5U-PRO Multi-Function Valve help
Old 06-26-2009 | 12:02 PM
  #33
InboundLZ's Avatar
InboundLZ
My Feedback: (10)
Default RE: EVSD-5U-PRO Multi-Function Valve help
Dirk means have you checked this?
4. Please notice the valve surface light change V1~V4. (in mode 2)
*(mode 2) The normal change light is as follows :
On power → V2-(Gear in) & V4-(Door close).
Press
that would mean you have the V1 reversed and the airlines connected incorrect?
Arrrrrrrrrrrrrggggggggggggg!
My valves and lines are connected correctly, period. The system works perfectly in every way EXCEPT upon system power up. I am going to have to shoot a video because words are not getting it done.
This valve is has a serious design flaw or the ones Chad and I have just happen to be broke in the same exact way.
