[quote]ORIGINAL: srt10
It all depends on what batteries you are using..
If you go with 3s on the VXL 3500 you should be fine using a small prop..
but if you want to use 4s the kv of the motor is way to kigh for a boat, even on 2s it will have good rpm to run fast.
ORIGINAL: Black0ut
hey. I used to be into nitro powered stuff until i got my blade 400 heli that had a brush-less outrunner 420 motor in it. Electric motors these days are so advanced and powerful.
so here is the scoop.
I have a nitro vee. The local pond doesn;t like the Vee as it is very very loud. The pond is very close to my house, and i rather not drive around looking for a new one. Nitro engines also require lots of maintenance.
It also doesnt go very fast.
I would like to use a Velineon 3500 brushless power system as they came down in price to just over $150.00.
I would like to use the same stock receiver found in the vee.
It needs to be LiPo powered as well.
Does anyone know how i could drive the propeller drive directly without off-setting the motor and using gears?
I also need to mount the motor on the aluminum plate that comes with the boat... any ideas on mounting solutions?
Anybody know of any other motors/ESC that are cheep and fast?
People are telling me that this is too much power... but since when is too much power too much? I mean, i need to at least break the sound barrier.
<br type=
is this directed towards me or the originator of the thread? im going to use the mamba monster 2200 system no vxl for now anyway
