RCU Forums - View Single Post - Interference
Thread: Interference
Old 06-29-2009 | 02:10 PM
Jim Cattanach's Avatar
Jim Cattanach
Default RE: Interference
ORIGINAL: Jezmo
In most ignitions the shield IS grounded through the plug. Think DA50 and all the clones out there. It seems, in your case, the braid is not making good contact with the metal cap that goes over the plug so you will have to ground it as you have and just make it permanent.
Just for curiosity what make of engine/ignition is it?
The engine is a 26cc J'en from Just Engines in the UK. I made sure the plug cap was pushed on fully. Looking at the cap, the only contact with the plug appears to be at the top of the plug. At no point does the body of the cap touch the hex of the plug.
What is the best way to ground the plug lead? Is it ok to just run a wire from the case of the ignition box to the engine, or fix a wire to the actual plug wire braid & ground that?
