RE: New LEO 110 build
did the engine stop running when the prop hit or did it keep running
check the engine not running turn it by hand and listen for any strange sounds or rough or hard to turn by hand
if the prop strike hit hard enough you may have bent one of the push rods
check the valves and clearance also
make sure glow plug is okay a Saito are nown to run a little hot than others
these are just of a few starting points
