RE: Interference
CHXL IGNITION SYSTEMS
We put each CHXL ignition through a series of tests to assure that it meets our specs.
All CHXL systems include computer timing control and stainless steel spark plug covers.
227. CHXL single system for 10mm NGK CM-6 or Denso U20M-U plugs ..................................... $79.95
228. CHXL single system for 14mm NGK BPMR6F or Champion RDJ6 or 7J,
5/8 hex, taper seat plugs............................................. .................................................. .................. $79.95
229. CHXL single system for 14mm NGK BPMR6A or Bosch R-10, 3/4 hex, taper seat plugs ..... $79.95
241. CHXL twin system for 10mm NGK CM-6 or Denso U20M-U plugs ......................................... $99.95
242. CHXL twin system for 14mm NGK BPMR6F or Champion RDJ6 or 7J, 5/8 hex,
taper seat plugs............................................. .................................................. ............................... $99.95
243. CHXL twin system for 14mm NGK BPMR6A or Bosch R-10, 3/4 hex, taper seat plugs
(will not fit Champion RCJ6Y) .................................................. .................................................. ... $99.95
Bosch metal spark plug cover for short 3/4 hex plugs (Champion RCJ6Y or 7Y) add $12.00 per lead
148. CHXL ignition system and timing kit for Zenoah G-20 or G-26 (with electronic ignition) ......... $95.95
We have CHXL Ignitions for many other engines. Call to see if we have one for your engine.
We also have replacement CHXL Ignitions and timing kits for most of the Chinese engines.
These run from $99.00 to $130.00 depending on the number of machined parts are required.
More Data....compliments of Capt,n
