[8D] Well I finally got my Creeping Death Turret recoil to work decently. I sprayed the silicone lube to the barrel and that helped a lot. It still seems to jam up though. The barrel sleeve is epoxied to the brass sleeves that recoil and I tried to slip it off and twist it and it won't come loose so that's good. I also tried prior to this to center the brass recoil unit but would not center at all. It's way off so I think that's why it's jamming up. I have to spray a liberate amount of the silicone lubrant to keep the recoil moving smoothly prior to firing. The firing mechanism however works flawlessly as I loaded up the magazine and filled the commmanders cupola. It fired every round without missing a shot. I dont' think I can do anymore to the recoil other than taking it out completly so I am content to leaving as is for now till I can stomach tackling that issue. Overall though I am pleased with the Turret.
Thanks for the suggestions guys.
